Jennings
Jennings
Postby sparkyct55 » Fri Nov 17, 2017 6:11 pm
Can anybody tell me something about this machine?
sparkyct55
Re: Jennings
Postby RameGoom » Fri Nov 17, 2017 8:23 pm
It's a Jennings J400, electronic non-microprocessor powered. I have restored a number of them. Difficult electronics, and prone to acid damage from the memory battery.
When they work, they work well. Are you trying to get it going?
RameGoom
Re: Jennings
Postby sparkyct55 » Fri Nov 17, 2017 8:37 pm
Going to try. Don't want to spend a lot of money. Bought it for $50. Have to get a voltage converter to boost it to 220v.
sparkyct55
Re: Jennings
Postby RameGoom » Fri Nov 17, 2017 8:59 pm
Keep us updated. I have a wiring diagram if you need it.
RameGoom
Re: Jennings
Postby sparkyct55 » Fri Nov 17, 2017 9:32 pm
Will do, Thanks!
sparkyct55
Re: Jennings
Postby sparkyct55 » Thu Nov 23, 2017 12:50 pm
Couple more question. What is the purpose of the white push switch to the left of the hopper?, the small push switch on the fuse plate, and the key switch to the rear of the pull handle side
sparkyct55
Re: Jennings
Postby RameGoom » Thu Nov 23, 2017 2:34 pm
Don't know about the pushbuttons, but the key switch on the right is an audit switch, one you won't ever use for home use.
The only pushbutton I know of is the one on the logic PC board - tilt reset switch.
RameGoom
Re: Jennings
Postby sparkyct55 » Fri Feb 09, 2018 12:55 pm
The Jennings j400 I got has a sideplate saying 220v
I'm assuming that it was ate up for the European market. The base came with what I think was a voltage reducer to go from 220v to 110v. So is the machine a 110v?
sparkyct55
Users browsing this forum: No registered users and 23 guests
