by nvmos2 » Wed Apr 30, 2014 12:55 pm
Greg;
I'm going to address your PM on this thread since it may have wider interest and there are other guys here who know more than I do and may add comments.
Your sample tokens are in the mail; they were made by Mills, so would be "correct" for your FOK.
I see no reason why they would not work, but your check detector must be properly set to accommodate the closer tolerances of the smaller center hole.
Several years ago, I undertook the project of stocking my slots and trade stimulators with the "correct" tokens, as they would come from the factory.
There is actually a lot of info available with a little digging:
"Mr. Token" used to contribute a recurring column, The Token Corner, in The Coin Slot and successor magazines; don't know if he's still around; since he collected coin-op, he may even be on this forum.
He had thousands of tokens and, in years past, he supplied many collectors with tokens for their machines.
There are regional and a national Token Collector clubs with their own magazines, websites, etc.
The "OLY" referred to above is from the Atwood system of cataloging tokens, which I believe is the standard for most token catalogs/books/price guides and includes most, if not all, slot/trade stimulator tokens.
I find the system not very good and hard to use, but I guess that, if you're a token collector and get the hang of it, it does the job well.
Tokens can be found at coin shows; many coin collectors look down their nose at tokens and sell them at low prices, but you have to dig for them and it's hard to find them in large quantities.
Private token collectors are a good source, but it helps if you know the Atwood system to identify what you're looking for since there are probably millions of different style tokens.
I found one collector who was able to provide me with hundreds of slot tokens.
By the time tokens get to dealers or Flebay, the prices are way high.
I occasionally sell excess tokens on Flebay for half or less of what you'll usually see them at.
