WATLING TORCH FRONT CENTER CASTING
Postby rtmccurdy » Mon Dec 08, 2014 3:50 pm
WANTED: CAST IRON WATLING CENTER FRAME (L415A WMC) FOR A TORCH FRONT GOOSENECK. PART HERE HAS A SMALL CRACK AND IS THE SMOOTH CHANNEL. EITHER STYLE
IS FINE. I ASSUME THE BLUE SEAL USES THE SAME CASTING?? THANKS!
rtmccurdy
Re: WATLING TORCH FRONT CENTER CASTING
Postby mechanic » Wed Dec 10, 2014 4:49 pm
If its cast iron a good welder should be able to fix it, it may need to be tooled down after.
Postby rtmccurdy » Wed Dec 10, 2014 5:17 pm
Anyone you could recommend? As I mentioned it is a hairline crack with a tiny piece missing.
rtmccurdy
Postby rtmccurdy » Wed Dec 10, 2014 5:22 pm
Here is a picture. The casting will be stripped of course.
rtmccurdy
