Northwestern 31 key for the base lock
Postby drishoff » Thu Oct 29, 2015 8:14 pm
Northwestern 31 bottom plate is locked. The lock is marked NC 14 Does anyone know where to get duplicates for this? Or is this one that needs to be drilled? Thanks in advance David
drishoff
Re: Northwestern 31 key for the base lock
Postby drishoff » Fri Oct 30, 2015 5:19 pm
Here is a pic of the lock
drishoff
Postby mrslot1 » Fri Oct 30, 2015 6:59 pm
From what it looks like to me is a Chicago lock, inside is waffers, you can try to pick it, if you do, I rekey those, I have blanks and pre cut,
let me know mrslot1@aol.com
thanks Dave
mrslot1
Postby drishoff » Fri Oct 30, 2015 8:46 pm
Seemed like the whole lock wanted to turn. Put some liquid wrench around the cylinder and let it set for a few minutes. Put a small screw driver in it on a small vise grip and it opened. Either the wafers were also stuck in the unlock position or there are no wafers. At least it is open. I will email you later this weekend and give you my cell number and we can talk.
Does anyone know where to get rubber feet with this type of wire to fasten them?
I have more wanted items for slots and trade stimulators. What is the board standard on posting? Should I post each item separate as long as it is a different machine?
rubber feet pin
open lock
drishoff
Postby mrslot1 » Sat Oct 31, 2015 5:10 am
I have rubber feet for trade stimulators too!
Thanks Dave
mrslot1
