Parts for FOK
Parts for FOK
Postby sam2002 » Mon Dec 28, 2015 2:08 pm
Hello
Looking for a few parts for an FOK . Need a back door with lock also looking for the cover that fixes to the gooseneck between the door and gooseneck .
Thanks for any help locating these parts
Sam
Re: Parts for FOK
Postby altort » Tue Dec 29, 2015 7:13 pm
Hi Sam
That back door for the FOK is pretty hard to come by, I have cut and stretched a standard Mills door in the past,
repro doors are available and I believe Dave Berten has them as well as the rear lip, I might have the skill stop casting that you are looking for, I will be back in my shop next week and I will look for it as well as the vender linkage that you also need.
Al
Re: Parts for FOK
Postby sam2002 » Tue Dec 29, 2015 9:23 pm
Al sounds terrific . Thanks !
Re: Parts for FOK
Postby sam2002 » Mon Jan 11, 2016 2:00 pm
Still looking for a door as well as the gooseneck back lip
Sam
Re: Parts for FOK
Postby sam2002 » Wed Jan 27, 2016 4:35 pm
sam2002 wrote:Still looking for a door as well as the gooseneck back lip
Sam
Still on the hunt for a door and back lip
Re: Parts for FOK
Postby Robgirard64 » Sat Jan 27, 2018 6:55 pm
Sam...did you ever find door and lip for FOK?
Robgirard64
Re: Parts for FOK
Postby sam2002 » Sat Jan 27, 2018 9:15 pm
Get ahold of Dave Berten here on the forum.
Mrslot1 he should have reproductions
Re: Parts for FOK
Postby oldslotman » Tue Jan 30, 2018 8:21 pm
Maybe a FOK door.
Re: Parts for FOK
Postby mechanic » Tue Jan 30, 2018 8:52 pm
If this machine has a backlip then the all steel door is the wrong one for it. Gooseneck FOK took the metal frame door wqith wood center panel. The ones shown in the pics are for the double eagle FOK silent escalator model.
Re: Parts for FOK
Postby oldslotman » Tue Jan 30, 2018 9:01 pm
mechanic wrote:If this machine has a backlip then the all steel door is the wrong one for it. Gooseneck FOK took the metal frame door wqith wood center panel. The ones shown in the pics are for the double eagle FOK silent escalator model.
Thanks for the info.
