RAT Coin Gateway
RAT Coin Gateway
Postby imagixx » Wed May 11, 2016 9:25 am
Coin check lever, broken here.
I'm looking for a Watling Roll-a-top coin gateway, *the lever* which
determines if a coin is in play in the escalator and if so, feeds
subsequent coins to the return.
imagixx
Re: RAT Coin Gateway
Postby mechanic » Wed May 11, 2016 3:22 pm
Your best bet is Larry Debaugh !! watling1 @comcast.net If he does not have it you may have a hard time finding one. Later Jim
Postby Richard13 » Wed May 11, 2016 3:54 pm
I just out my Watling back together and done want to take it apart again. Do you have the broken or missing part? These old cast iron and cast brass machines are somewhat forgiving so if you have missing parts they can be brazed together again and if not depending on how much is missing I bet it could be built up with braze and ground down and filed to fit and function. I fix several OOPS delivery breakages for myself and others. Usually it's the front left corner of the cast iron base that breaks off and needs brazed back together. You can paint with cast iron paint and not tell a repair has been made. I'm sure you know someone with an oxy acetelyn set up that might tinker that back to life.
Richard13
Users browsing this forum: No registered users and 23 guests
