Caille top mechanism coin slide
Postby briank » Mon Feb 06, 2017 11:10 am
Just picked up a Caille Superior that played nice until I got it home. Upon further investigation it looks like I need a coin slide in 25 cent denomination ......anybody have one for sale. I may be able to v then weld and gring if I need to but hoping somebody has one for sale. Thanks
briank
Re: Caille top mechanism coin slide
Postby briank » Thu Feb 09, 2017 1:47 pm
Looks like another needle in a haystack that Im looking for. Has anbody had luck mig welding one? The only issue I see would be on the inner part as it is very close to the other side so Im not sure of how good a weld could be done there. How much stress is on this part? Im wondering how this broke. Only thing I can figure out is that coin got jammed and somebody forced the handle and broke the top coin slide??
briank
Postby damikeguy » Thu Feb 09, 2017 3:13 pm
Not a lot of stress on it. I'm sure if you find a good welder it could be repaired. There will be some cleanup to be done after. Filling and stoning it so that it moves freely.
Mike
damikeguy
Postby briank » Thu Feb 09, 2017 6:18 pm
Thanks. Im good at the finishing work but not welding...my mig is out of gas and I dont like to do it. Weird thing is I weld sheet metal better than thicker metal. Im going to hunt down a local welder and see if he will weld it. Then I will finish it. I will still be on the hunt for another top slide though as a backup.
briank
