widget2k4:
If you don't mind, could you send me the serial numbers from your 3 "Reel 21" machines?
They will be stamped on the outside bottom of the case. I have been logging these numbers
for many years. Daval had a different process, in the way they produced their many different
models, as most individual models did not have it's own serial range, and were intermingled.
I wish that I could help you with your gumball parts. I used to make all of the parts for the
Daval models, but am temporarily out of stock, and don't know when I will be doing more.
The only part that I know of that is available at this time, is the gumball delivery cup casting.
That was from Paul Hindin, at (
bedvibr8or@aol.com).
