Mills/Buckley/Pace Half-dollar payout fingers
Postby kmorris8 » Wed May 02, 2018 12:32 pm
I need a couple of the offset-bent (to accommodate the high stack) horizontal payout slide release fingers. No one sells parts anymore...
Anybody have something close? Thanks.
kmorris8
Re: Mills/Buckley/Pace Half-dollar payout fingers
Postby oldslotman » Wed May 02, 2018 4:16 pm
I believe you can use the regular fingers you just have to have the two guides that mount to the base to give the fingers the right separation. May just need minor bending. The guides are the most important parts.
Postby kmorris8 » Wed May 02, 2018 7:06 pm
Yes, I see what you mean. In that case I need to find a half-dollar guide at least for the position nearest the slides. Thanks.
kmorris8
Postby oldslotman » Wed May 02, 2018 8:09 pm
kmorris8 wrote:Yes, I see what you mean. In that case I need to find a half-dollar guide at least for the position nearest the slides. Thanks.
MLB-3610 is the part number for the 50 cent lower payout lever guide. You also need the payout lever guide shim. MLB4147 which is the same as the quarter one. The 18 and 14 and 10 and 2/5 coin vertical payout levers are the same as the 5 cent machines. The lower jackpot payout slide lever is also different MLB7889. I believe the 5 and 25 cent levers will work for the rest.
Postby kmorris8 » Thu May 03, 2018 1:16 am
Thanks again. I just can't find a source for these parts.
kmorris8
Postby oldslotman » Thu May 03, 2018 8:29 am
What machine are you working on?
Postby kmorris8 » Thu May 03, 2018 10:18 am
It’s a Buckley Criss Cross. Mills mech I took another look and they no I can make the fingers and guide work. Just need one more horizontal finger.
kmorris8
