Cub, Imp vacuum pump wanted
Postby Batlestar60 » Sun Dec 15, 2019 10:19 am
Anyone know where to get a vacuum pump like in this photo?
Batlestar60
Re: Cub, Imp vacuum pump wanted
Postby integ194 » Fri Dec 20, 2019 1:44 pm
Is yours missing or is it non functional?
integ194
Postby Batlestar60 » Mon Apr 13, 2020 3:56 pm
I was trying to adjust the one in my Cub and it just crumbled into pieces,
Batlestar60
Postby sct2011 » Thu Apr 16, 2020 7:14 am
Same thing happened to me. If the pieces aren't too small and you saved them you may be able to make a repair until you get a replacement. Both screw lugs and adjustment screw on the end broke off on mine. Repaired with hobby brass tubing and JB-Weld epoxy. On the end I slid the tubing over the broken pieces with epoxy and drilled the air hole in the appropriate place. Glued with lightly greased adjustment screw in place until epoxy started to setup. On the lugs I used split tubing (horseshoe shaped) cut to proper height and epoxy in place. Light adjustments needed with Dremel grinder needed for snug fit. Worked for me.
Hope this helps.
sct2011
