Looking for the back bonnet casting for a Mills Extraordinary
Hope I’ve got the name right: this is the casting that is in contact with top of the back door.
The one I have is damaged and doesn’t allow the door to latch.
thanks!
mbarthelow wrote:
rtmccurdy wrote:The bonnet on my standard gold award model is MLB 3914. On my vender front it is FOK 3827. Will not fit each other although they look similar. As mentioned, the Page Boy console and 50-cent models have different numbers and designs. So check the casting number in your bonnet and look for a similar version.
mechanic wrote:mbarthelow wrote:
that casting can be repaired. Since it is not part of any design or polished area you should be able to take it to your local welding shop and have them build up the broken area. Grinding and filing the casting will be necessary then painting should make it look like it was never damaged.
