Mills Hi-Top Base
Mills Hi-Top Base
Postby 63mini » Fri Jan 08, 2021 5:50 pm
I have a future project that will require a replacement oak base for a Mills Hi-Top. I think the termites and slot techs had too much fun with this one. #-o Please let me know what you have. Thanks!
63mini
Re: Mills Hi-Top Base
Postby collector1 » Sun Jan 10, 2021 11:21 pm
you can look on EBAY item number 114614967158 as I think they have 2 bases that may work for what you are looking for. check them out yourself. hope they work for you
collector1
Postby 63mini » Mon Jan 11, 2021 6:19 pm
collector1,
Thanks, I am aware of that listing. I have been in contact with the seller. It is my plan "B". I am still hoping to find an original. If not, then plan "B" may kick in. Hopefully, I won't have to go to plan "C" and hatchet out some oak scraps.... :shock:
63mini
Postby 63mini » Tue Mar 30, 2021 5:53 pm
Bumping this up one time. Still looking for one.
63mini
Postby capt7310 » Wed Mar 31, 2021 4:17 am
Hi 63 mini, I'm in the same situation. Your base is more manageable then mine. I've been looking for awhile and I'm going to have to re-construct something, can't find a base anywhere but if I do I will let you know. If I make my own I'll shot you a pic. Good Luck
capt7310
Postby 63mini » Wed Mar 31, 2021 6:02 am
capt7310,
You're right. I can see you have some work on your hands with that base.
I am considering removing the pieces of my base and running them through a planner and remove most of the damaged area. Then laminating new oak planks to the bottom. I think this will work, but there will still be some pocket/voids between the laminated boards, as the bug damage is pretty deep in a couple of areas. Maybe epoxy could fill those spots.
63mini
Postby 63mini » Sun Jun 13, 2021 12:41 pm
The base is no longer needed!
I was able to salvage the one that I had. Basically, I filled the rotted area with epoxy. Once that cured, I ran it through my planer and removed enough material to laminate new oak to the bottom. It turned out better then I expected. It won't win any best of show awards :-D . But, it will work just fine for home use when finished.
63mini
Postby mechanic » Mon Jun 14, 2021 5:08 pm
TURNED OUT VERY NICE
Postby shortrackskater » Mon Jun 21, 2021 3:45 pm
Nice!!!
shortrackskater
