Key needed for a Mills
Postby Foxyjosh » Sat Jul 03, 2021 3:55 pm
Hello, I just bought a 1920s Mills slot machine without a key. How do I go about getting a key that works?
Here is a picture of my machine:
I'm Foxyjosh and I approve this message.
Foxyjosh
Re: Key needed for a Mills SOLD
Postby radiorich123 » Sun Jul 04, 2021 5:31 am
If you have a mills lock on it the key number is on the lock. I have a mills lock with the key if you need one for $95.00 and 5.00 for shipping in the USA.SOLD
Postby Foxyjosh » Sun Jul 04, 2021 12:42 pm
There is nothing on the outside of the machine for a number.
Foxyjosh
Postby radiorich123 » Sun Jul 04, 2021 1:27 pm
The mills lock number is inside on the lock. If the machine is lock may be a old timer lock smith can open it. Good luck.
Postby MONTI » Sun Jul 04, 2021 1:46 pm
If the back door on the Castle Front is original than it will look like the one in the below photo and the lock will only show the key opening which would look like the one circled within the below photo!
If the key entry on the lock is like this one than it is original so having a locksmith pick it or even try would be unlikely if it is an original lock which has not been re-keyed at one time as sometimes in re-keying an original Mills lock some tumblers are removed making it easier to pick!
If your lock is a later replacement style as commonly used picking it would be easy, or should be!
Oh and so you will know depending on the serial number the Mill's Blue Front called "Castle Front" by route operators is probably mid 30's!
Bona Fortuna!
Postby Foxyjosh » Sun Jul 04, 2021 1:56 pm
It looks like it might be original. I'll try pestering the seller to see if he can find the key.
Foxyjosh
Postby Foxyjosh » Sun Jul 04, 2021 2:13 pm
Where would the serial number be located?
Foxyjosh
Postby Chendrix » Sun Jul 04, 2021 2:33 pm
I once offered a seller an extra $100 for the key, if he could find it within 3 days. He found it in 24 hours and brought it to me.
I didn’t have to drill a lock, then spend $100 for a new original lock. :D
Chendrix
Postby MONTI » Sun Jul 04, 2021 2:36 pm
Foxyjosh wrote:It looks like it might be original. I'll try pestering the seller to see if he can find the key.
If original key it should look like the one in the above photo I posted and the serial # should be a five digit number stamped in the casting somewhere similar to this one!
Postby Foxyjosh » Sun Jul 04, 2021 2:56 pm
I’m not sure where that location is on my machine. I have a casino security bar to reinforce the door. Could the S/N be hidden under that?
Foxyjosh
