Pulver short case parts source
Postby altort » Fri Feb 18, 2022 12:26 pm
I have recently picked up two Pulver's short case gum venders, missing a few parts, both missing the lock bar that the lock latches to that attaches to the wall bracket, and one is missing the sheet metal cross bar panel that is behind the glass, looked on Grow rivers web sight and no parts for this machines.
any one have the parts I need or can post a good picture and dimensions of the lock bar, looks like a very easy part to fabricate if I know the correct size and shape.
also is there a parts source some were for these venders?
Re: Pulver short case parts source
Postby RameGoom » Fri Feb 18, 2022 3:07 pm
I have made the prison bar insert out of black acrylic, cut with a laser. You'd never know it wasn't sheet metal.
Also have powder coated the original part in the past.
Since it's behind the glass, not an issue using different material.
Postby altort » Fri Feb 18, 2022 4:58 pm
Thanks for the reply,
I don't have a problem fabricating the prison bars if I cant find an original replacement, I will just use the one I have to make an exact copy, wish I had an original rear lock bar to fabricate one as well, looks like it would be a real easy one to make up if I had one to measure and copy.
I am kinda surprised that such a common machine, lots of them out there but cant find any source of parts for them, original or reproduction,
