Groetchen Repairs
Columbia Machine. Cleaning this up to make it functional - got it with a nasty coin jam and inop on the pull handle.
Got it working mostly, but it seems to get a coin jam when the upper tractor feeds the large carousel - tries to put a second coin in where there is currently a coin. Doesn't seem to index properly, only some of the time.
The mechanics of this machine is complex. I'm missing some sort of cover that goes over the top of the coin carousel, which might be why I get these coin jams. The cover would likely allow the tractor to feed in the right place and keep the guide cover in position. There is a cover over the coin outlet from the upper tractor, held in by some weird spring, and it pops off when the jam happens there.
Anyone know if that round cover with the keyhole slot in the middle is available or possibly have one? Or, do I fabricate something (my second choice).
Pics for detail. Someone has been in there bracing some stops with sheet metal and a crude brazed-on plate, no doubt to compensate for wear.
Any advice from you experts?
