Mills jackpot removal
PostPosted: Sat Feb 10, 2024 1:03 pm
by TJF
Hello,
This is a Mills Castle Front machine. I need to replace the jackpot glass. I presume I need to remove the jackpot mech to do this. What's the easiest way to get it out?
Thank you!
Re: Mills jackpot removal
PostPosted: Sat Feb 10, 2024 2:08 pm
by oldslotman
Take the front casting off. When you replace the jackpot there is one lever that has to be in the correct position for the jackpot reserve to work.
PostPosted: Sat Feb 10, 2024 2:24 pm
by TJF
oldslotman wrote:Take the front casting off. When you replace the jackpot there is one lever that has to be in the correct position for the jackpot reserve to work.
I managed to get it out, and I'm guessing the lever you refer to is what's referenced here in this video https://www.youtube.com/watch?v=dA8QUP2T57E
However, mine appears to have a piece broken off. (to be clear, I'm referring to the vertical part in the background of the circle where it appears something cracked off) What is this part, how necessary is it, and can I get just this piece? :-(. Also, that spring on the right appears to be two springs connected together. I'm guessing that's not right either.
PostPosted: Mon Feb 12, 2024 4:55 pm
by Bally Bill
Hello and Welcome to the forum, Here some pictures of my castle front jackpot and a reference page to help you along.
