by MrDeeBee » Wed Nov 11, 2026 7:38 am
There is a hook that when lowered, prevents the upper payout assembly from moving forward. There is a spring loaded switch that when moved to the right raises the hook and holds it up. When moved to the left it lowers the hook. At that point a lever can move the hook up or down. Now the question. SHOULD THE SWITCH BE SET TO THE THE RIGHT OR THE LEFT FOR REGULAR PLAY? When discovered, the hook was stuck down behind finger rod not allowing forward movement of the payout fingers and the switch was also stuck to the left. I mean stuck like cement. All help is appreciated. Than you.
