Was just given an antique slot machine. What do I have?
Re: Was just given an antique slot machine. What do I have?
Postby RameGoom » Thu Feb 15, 2018 4:52 pm
Key and lock. Key is shown on one side, then the other. Called a Wiggle Cut. Note the notch on the key where it would only go in one way. Upside down and it won't turn. The wiggle cuts are different on each side, and the key tumblers have to correspond to both so there's a set of tumblers on both sided.
Postby radiorich123 » Thu Feb 15, 2018 4:58 pm
HI
Here is the Mills lock and key.
Rich
Postby kxh121 » Fri Feb 16, 2018 2:27 am
I sent you a PM, if you are close to my location I can help. I have a couple hundred original Mills keys and I am sure one will fit.
Ken
kxh121
