Norris Master Gumball Machine
Postby rodgers330 » Fri Dec 02, 2016 10:38 am
A few years ago I purchased a Norris Master machine (photos attached) and would like to add gumballs to give it a more desirable appearance. I don't know the correct size of gumballs but the dispensing hole appears to be just under 1" in diameter. It may be exactly 1" but it's difficult to accurately measure. Does anybody have a recommendation for the correct size gumballs and a reputable vendor? Thanks in advance!
P.S. My real passion is antique radios from the 1930's and I also own 5 jukeboxes (Wurlitzer 1015, 1080, Seeburg 147, Seeburg C and Rockola 1448)
rodgers330
Re: Norris Master Gumball Machine
Postby radiorich123 » Fri Dec 02, 2016 12:00 pm
HI
Order here for your size it should be around 7/8 dia or less.
https://www.gumballs.com/?gclid=CPCfqaS ... DQodHBABpQ
Rich
Postby DeTrana » Fri Dec 02, 2016 12:21 pm
I use marbles, which hold up better
DeTrana
Postby SLOT DYNASTY » Fri Dec 02, 2016 3:39 pm
DeTrana wrote:I use marbles, which hold up better
Yes, the marbles do hold up better, but bad for your teeth. Your Dentist will be happy to see you! :D
