Jennings
Fri Nov 17, 2017 6:11 pm
by sparkyct55
Can anybody tell me something about this machine?
Re: Jennings
Fri Nov 17, 2017 8:23 pm
by RameGoom
It's a Jennings J400, electronic non-microprocessor powered. I have restored a number of them. Difficult electronics, and prone to acid damage from the memory battery.
When they work, they work well. Are you trying to get it going?
Re: Jennings
Fri Nov 17, 2017 8:37 pm
by sparkyct55
Going to try. Don't want to spend a lot of money. Bought it for $50. Have to get a voltage converter to boost it to 220v.
Re: Jennings
Fri Nov 17, 2017 8:59 pm
by RameGoom
Keep us updated. I have a wiring diagram if you need it.
Re: Jennings
Fri Nov 17, 2017 9:32 pm
by sparkyct55
Will do, Thanks!
Re: Jennings
Thu Nov 23, 2017 12:50 pm
by sparkyct55
Couple more question. What is the purpose of the white push switch to the left of the hopper?, the small push switch on the fuse plate, and the key switch to the rear of the pull handle side
Re: Jennings
Thu Nov 23, 2017 2:34 pm
by RameGoom
Don't know about the pushbuttons, but the key switch on the right is an audit switch, one you won't ever use for home use.
The only pushbutton I know of is the one on the logic PC board - tilt reset switch.
Re: Jennings
Fri Feb 09, 2018 12:55 pm
by sparkyct55
The Jennings j400 I got has a sideplate saying 220v
I'm assuming that it was ate up for the European market. The base came with what I think was a voltage reducer to go from 220v to 110v. So is the machine a 110v?
