Help Identifying These?
Mon Jun 30, 2014 8:02 am
by AntiqueRick
Anyone have any ideas what these machines are?
Thanks!
Re: Help Identifying These?
Mon Jun 30, 2014 10:32 am
by toydoc
Assuming it has wooden sides, I would guess it is a Mills operator's bell. The casting looks similar to those used on the cast iron fronts from the turn of the century.
Can't see denomination for coin nor other details from your picture. Do not think there were bronze versions done but rather nickel plated. Hope this helps some.
Mon Jun 30, 2014 11:09 am
by altort
Cant be sure from the pictures, but watling made a similar slot, I belive that the upprer casting on the watling had an eagle verses an owl on the mills umong other differences also cast iron verses aluminum
Mon Jun 30, 2014 3:03 pm
by Midcoast Vintage
from what is shown in the pics you supply,
these are watling.
some top castings have an eagle on top, and i have seen a couple with a large "W" in a very heavy block type font or script letter.
another easy "tell", or give away, is look at the mills logo in the lower right of the front casting... notice the owl has been removed from the center of the gear.
these machines should have round payout fingers going through the reel discs, as opposed to the later flat / stamped pay out fingers.
reel strips should be tin as opposed to paper, and should be marked watling under each bar symbol.
i have only seen the watling versions of this style in cast iron. i have not seen this style in aluminum.
i also believe these to be the last of the CAST IRON watlings.
i believe the first watling aluminum machines were the 4 column vendor ( similar to the mills f.o.k. ), and, the "LINCOLN DeLUXE", which is similar to the previous machine, (taller fok height case), , but with out the front vendor.
and, i believe the first of the aluminum watling's to become the traditional "flat top" style they became known for were the BABY LINCOLN", and the "BLUE SEAL" 4 COLUMN VENDOR FRONT with the big roll of mints cast diagonally across the front casting.
Mon Jun 30, 2014 8:12 pm
by TheFatman
Do a magnet test to be sure.
dave F
Mon Jun 30, 2014 10:08 pm
by AntiqueRick
Thanks for the replies! Here's more info:
One is 5 cents and one is 25 cents.
These are cast iron (per magnet test). I'm not sure if the copper plating was added by the manufacturer or by an owner at a later date. The gum vending is aluminum.
There is an eagle on the top of the casting - and I've added a pic of a part inside the machine the is stamped "W M CO" - I'd say Watling is the right call.
Serial number on these are stamped in the wood at the top and not on the machine. Both are in the 25,xxx range.
The reels have no names on them whatsoever....
Please let me know if you'd like to see more pics or info. Any idea on the model/date for these?
Thanks!
Tue Jul 01, 2014 7:11 am
by Whosignedmeup
Is there a "W" on the bottom of the base?
Tue Jul 01, 2014 8:23 am
by AntiqueRick
Not sure. They are at a friends house. I'll send an update as soon as I can take a look.
Thanks!
