Mills FOK Torch Jackpot Wanted
Postby thepennyarcade » Sun Nov 23, 2014 2:12 pm
Hi Forum
I am trying to finish off my Mills FOK gooseneck machine and I need a working complete jackpot.
Yesterday there was one on ebay but it was incomplete and never showed a front view to see what was missing.
I suspect a Mills Poinsettia has the same jackpot
Here is a picture of the jackpot I need
Thanks All
John
thepennyarcade
Re: Mills FOK Torch Jackpot Wanted
Postby SLOT DYNASTY » Mon Nov 24, 2014 1:34 am
The following pix, shows a Mills "Poinsettia" Jackpot, which is
not quite the same as the one you show for the "FOK".
Postby terick2104 » Mon Nov 24, 2014 4:55 am
The FOK jack pot on Ebay was mine. It appears to me to be complete. I took 3 pictures of every angle, but I screwed up by not flipping it over and taking a picture of the front. The front was complete and undamaged, you should have emailed me if you had any questions. Sorry you missed it, don't know where you will ever find another one.
terick2104
Postby flipper77 » Mon Nov 24, 2014 12:53 pm
The Mills Torch has a fairly unique jackpot and I believe this is different than even the more common Poinsettia JP. Here is the Torch JP and front - is this the part you need? Torch JP was quickly rushed into production by Mills - has that odd lever angled out 45 degrees to mesh with mech lever. If that is your machine, will be tough to find an available JP. Flip
flipper77
Postby terick2104 » Mon Nov 24, 2014 3:09 pm
I believe what he is looking for is a jack pot for a gooseneck FOK, like what I just sold on Ebay, mine was marked FOK right on the casting. I also believe the trip lever parts on the FOK jackpot would fit on a Pointsettia jack pot.
terick2104
Return to Parts WANTED
