RameGoom wrote:Aha! That would explain the block on the single cherry. But why didn't they post it on the payout card? Was it some sort of special win thing? It is a 10 stop mechanism so I just might pull that piece off
There are four stopped-cherries on the first strip, and one non-stop, so odds are 40% win on a single cherry? Blocking one of the four would give you only 30% odds which would explain why they put it there.
I think I'll just remove the bug, maybe re-do the payout card to add a single cherry win?
As oldslotman pointed out, there are no single-cherry pays on those old ten-stop mechanisms; single cherry payouts first showed up many years later, on 20-stop mechanisms. We can see by the starwheel in one of your pictures that you have a ten-stop mech. All cherry payouts should require
two cherries on the payline. What about the situation you describe makes you believe that unblocking the single cherry hole on the first wheel will payout all by itself ("single cherry win") without a second cherry also on the payline?
