Is it played reading the cards from left to right to make 21 or are the first 2 cards the house cards you play against? There's a utube video that shows the player playing the machine with the first 2 cards as the house you play against.
sam2002 wrote:I believe it a played left to right . On he first reel there is a card marked lucky card begin from the next card
SLOT DYNASTY wrote:Where did you get this photo from? I looked on eBay, and didn't see it. This looks like one of the Vegas Butcher redo's.
If it is, that is probably a recast jackpot. The repaint colors are not correct, and the reel strips appear to have been
changed, as those are not the style that came in this model, and will not have the 'Lucky Card' on the first reel.
I would definitely stay away from this offering. You say someone was playing it on a video. If it is who I think it is, he
has ended up with a lot of the Butchers stuff.
SLOT DYNASTY wrote:Hi Denny:
You made a good purchase on your "Hit Me" machine. It is totally original, with all the correct
untouched paint colors. Even though there is some scratched areas in the paint, I would leave
it alone, as it would lessen it's value, if you were to repaint, or even touch-up with colors that
don't match perfectly. Your reel strips & award card are also nice originals. The entire case, is
also in excellent condition, including the back door, (which is often missing), and looks to have
the original lock. The inside is squeeky-clean as well. This machine does not appear that it had
been on location very long, (if at all). The only downside I see, is that someone has removed
the jackpot, and apparently misplaced it. It is held in place by a lock & key. You may want to
contact the seller, as it could be laying somewhere, and he didn't know what it was off of. If you
need a pix of the jackpot unit to send him, I can send one your way. By all means, DO NOT buy a
recast jackpot from the Vegas Butcher, as those are the Worst castings on the planet. It is best
to have it missing, than go that route, with a machine as nice as yours. There is also a very slim
chance that an original will turn up someday, or even a junker machine, that it can be robbed of.
Denny wrote:I understand a penny, nickel, dime and quarter can be used but if someone put a quarter in and gets blackjack does the bar owner pay in quarters? That will be 25 quarters ($6.26) plus whateverer is in the jackpot if you hit blackjack. The machine says 1 cent on the award card and will most likely take in pennies and nickels. I consider this a big loss if the machine takes in pennies and pays out in quarters because one was used. So which is it, payout in quarters or pennies.
Denny
