Daval Penny Packs
Daval Penny Packs
Postby drishoff » Sat Dec 05, 2015 6:05 pm
Does anyone have case parts or know where castings of case parts are available for Daval Penny Pack machines. A base, a couple backs and a front. Thanks
drishoff
Re: Daval Penny Packs
Postby SLOT DYNASTY » Sat Dec 05, 2015 7:05 pm
I will check my stock, as I may have a base, and possibly a front. Are you missing them completely, or are they damaged?
Also, there are at least four different "Penny Pack" front castings, including the coin divider model. Also two different bases.
As for the back door, no originals are available. One of our Forum members has done recasts of them, and done correctly,
allowing for the shrinkage, so that they fit right. If he doesn't chime-in soon, send me a PM, and I'll send his contact info.
Postby drishoff » Sat Dec 05, 2015 7:51 pm
I have the base, back and front. They are damaged. One had the back pried off breaking the base, another had 5 small holes drilled up around the lock. Another back I need to dig out to get a picture of the damage.
The base damage is the yellow pic and the other one with the holes has 2 holes above the lock on the front case part and 3 holes on the back. one of those holes in next to the lock about 4 o'clock. Maybe someone here knows someone that repairs these where I could send them out or other suggestions.
drishoff
Return to Parts WANTED
