Want to buy Bolts for Mills cabinet
Postby ThirdGenAmusement » Fri May 17, 2019 6:47 pm
Hello,
I have a Mills FOK which is missing the bolts that go through the cabinet into the bonnet. The cabinet bolt and nut is a 10-24X1-1/4 pan head bolt. I am including a picture of it for reference.
I'd also like to find 2 fillister bolts nickel plated 10-24X.5" or longer. I am looking for original hardware to match the patina of the slot.
Thank you.
--John
ThirdGenAmusement
Re: Want to buy Bolts for Mills cabinet
Postby mechanic » Fri May 17, 2019 7:09 pm
I hate to be the bearer of bad news but the bolt in your pic is not a Mills. That style is for either a Pace or Watling machine. Mills had a square collar below the head and no knurling on the shaft.
Postby ThirdGenAmusement » Fri May 17, 2019 7:21 pm
mechanic wrote:I hate to be the bearer of bad news but the bolt in your pic is not a Mills. That style is for either a Pace or Watling machine. Mills had a square collar below the head and no knurling on the shaft.
Thanks for the reply! I was suspect it may not be the correct bolt. I appreciate the confirmation. Still would like to find original Mills bolts(2) if possible.
ThirdGenAmusement
Postby MONTI » Sat May 18, 2019 8:28 am
Check with Dave Berten at mrslot1@aol.com and if he does not have them he may be able to point you in the right direction!
Postby ThirdGenAmusement » Sat May 18, 2019 9:32 am
MONTI wrote:Check with Dave Berten at mrslot1@aol.com and if he does not have them he may be able to point you in the right direction!
Thanks Monti. I will shoot Dave an email. :D
ThirdGenAmusement
Return to Parts WANTED
