High Top spring ID?
High Top spring ID?
Postby rilaw » Fri Apr 10, 2020 3:05 pm
What is the name or part number of the spring that goes where I have this shinny new, not correct spring?
Also, if anyone has a useable CC-537-3 reel strip, let me know. It's missing just one strip, and it's a rough machine.
rilaw
Re: High Top spring ID?
Postby oldslotman » Fri Apr 10, 2020 8:28 pm
What color reel strip? Spring is MLB 160 extension spring [ 70062-CSP ]
Postby rilaw » Sat Apr 11, 2020 6:07 am
oldslotman wrote:What color reel strip? Spring is MLB 160 extension spring [ 70062-CSP ]
Thank You, I couldn't find that spring in the diagram in David Berten's catalog. The reel strips are silver, the two that are there are labeled: CC-537-1 (CH-1) 10-47 and CC-537-2 (CH-2) 2-48
I finally have it mostly working (need to order a spring set for the escalator as I have the wrong large spring as well, which I think is causing the nickles not to be cycling through (cycles fine out of machine)).
Since this is in poor condition, and missing the back door and bonnet, I don't want to drop $$ into it. It's just been a fun project to get from completely dead and abandoned to rough and working. Its my first mechanical regular slot (Own one console and a vest pocket).
rilaw
Postby oldslotman » Sat Apr 11, 2020 10:13 am
I do have two of the reel strips
Postby oldslotman » Sat Apr 11, 2020 10:14 am
Postby rilaw » Sat Apr 11, 2020 11:40 am
PM Sent, Thank You Again
Update: Reel strip found, Thanks again to Oldslotman!
rilaw
