Help Me ID This Mills Black Cherry Part
Postby WoodrailFanatic » Fri Aug 27, 2021 12:43 pm
I found this loose in my Mills 5 cent Black Cherry...was on the bottom of the cabinet in the far lefthand corner by the backdoor (when viewed from rear).
Can someone please tell me what it is/where it goes?
Thanks!
WoodrailFanatic
Re: Help Me ID This Mills Black Cherry Part
Postby Walter Newton » Fri Aug 27, 2021 5:23 pm
Is it the valve to the handle return pump?
Walter Newton
Postby WoodrailFanatic » Sat Aug 28, 2021 7:24 am
Walter,
Thanks for the reply. If you are referring to the adjustment screw that is in place on this machine. Also that screw is a "normal' one and has a nut on it so the depth of the screw can be adjusted.
But I am likely telling you something you already know! You were probably suggesting somebody may have replaced the original with this non-standard one.
If this is not the case and you are referring to some other part on the handle pump please let me know.
WoodrailFanatic
Postby Walter Newton » Sat Aug 28, 2021 5:39 pm
I wasn't sure of what the part was, I was just suggesting it was the valve adjustment due to the location in which you found it.
I was obviously wrong.
Walter Newton
Postby gsx11r » Sun Aug 29, 2021 7:48 am
Hello
Try this place.
On the upper of the right side mech.
Stephane
gsx11r
Postby WoodrailFanatic » Sun Aug 29, 2021 12:33 pm
Stephane,
Excellent suggestion as my mystery part has the exact same form factor.....but, alas, my mech has the part in place that you singled out .
The mystery part is smaller than your suggestion....the diameter of the part is close to half that of the one you pointed out.
Thanks so much for replying.
WoodrailFanatic
