Mills vendor monitoring sensing lever base
Postby briank » Sat Dec 24, 2016 7:54 am
Does anybody have the base plate (for lack of a better description) for a Mills gooseneck mint vendor. It sits at the front of the payslides and the mint sensing lever rests on it. I have a picture of it with a finger pointing to it courtesy of THE OWNERS PICTORIAL GUIDE figure c.13
briank
Re: Mills vendor monitoring sensing lever base
Postby briank » Sat Dec 24, 2016 7:56 am
Here is a picture of my slot and what is missing.
briank
Postby briank » Mon Dec 26, 2016 7:14 am
Or...if somebody can send me dimensions, I can make this piece. Thanks
briank
Postby gsx11r » Mon Dec 26, 2016 11:29 am
Hi
Mrslot1 must to have !
But I will post photos and size tomorrow for be sure that you find the good part !( 2 different parts for the same place !)
Stephane
gsx11r
Postby gsx11r » Tue Dec 27, 2016 7:03 am
Hi Again
Here is what I have !
You need this !But there are an other model , but not good for your slot machine !
The other model :
The size :
If you need more info , just let me know !
Stephane
gsx11r
Postby briank » Tue Dec 27, 2016 7:43 am
Wow! Thank you very much, Ill get to making this, should not be very difficult. What models was the other piece used on?
briank
Postby gsx11r » Tue Dec 27, 2016 8:11 am
The other gone on all other models :Silent like war eagle , roman head?... ( except the one with Front vendor, you need the other !) and hig top .
Stephane
gsx11r
Postby briank » Tue Dec 27, 2016 12:17 pm
Stephane, I made the payout slide stop (is that the correct name or is it called a sensing lever stop?) Anyways, I went to put it in and Im missing something else that goes behind that. It appears to be a lever of some sort. I see it in your picture and if you look at mine again, you can see what os missing. Im not sure what else goes with that lever that runs vertically.
briank
Postby briank » Tue Dec 27, 2016 12:21 pm
Its part 595c per Bueschels coin slot #17, anti cheating lever.
briank
Postby mechanic » Tue Dec 27, 2016 2:22 pm
There are more than 4 different slide stops for Mills. The two pictured each have another variation.
Return to Parts WANTED
